Alert triage is the first assessment of an alert: deciding whether it is real, how bad it is, what it affects, who owns it and what to do next. Incident triage is the same assessment for a confirmed incident, where the outcome is a severity, an owner and a first response.
This page is about triage in IT operations and site reliability engineering: infrastructure, applications and networks, and the on-call engineers who run them. It is not about security operations, where “alert triage” means sorting detections in a SOC. The steps look similar. The evidence and the tools are different.
In short:
- Triage answers five questions: is it real, how bad is it, what is affected, who owns it, and what changed.
- Triage is slow because an alert carries a symptom and none of the answers. The engineer has to collect the evidence by hand, usually across several tools.
- When every alert costs twenty minutes to understand, teams stop looking at most of them. That is how real problems get missed.
- The fix is not a better sorting process. It is to make the evidence arrive with the alert.
- With Netdata, any alert is explained in about two minutes, one click away, so alerts no longer pile up for triage.
What is alert triage?
An alert is a rule that fired: a value crossed a limit, a check failed, a service stopped answering. It says that something looks wrong. It does not say whether a person needs to act.
Alert triage closes that gap. For every alert that reaches a person, someone decides one of four things:
- Ignore it. It is a false alarm, a known condition, or it already recovered.
- Watch it. It is real but not urgent. It goes to a ticket or to working hours.
- Act on it. It is real and needs work now, and it stays with the person who has it.
- Escalate it. It is an incident. It gets a severity, an owner and a response.
What is incident triage?
Incident triage starts when the answer is “this is an incident”. Its job is to size the problem and put it in front of the right people fast: set a severity, name an incident owner, state what is affected, and decide the first action, which is often mitigation before the cause is known.
The terms around triage are often mixed up:
| Term | Question it answers | Output |
| Alert triage | Does this alert need a person, and how soon? | Ignore, watch, act or escalate |
| Incident triage | How bad is this incident and who takes it? | Severity, owner, scope, first action |
| Incident response | How do we restore service? | Mitigation, communication, recovery |
| Root cause analysis | Why did it happen? | The cause, and the fix that prevents a repeat |
| Postmortem | What do we change so that it does not happen again? | Actions, owners, follow-up |
In practice the first hour of an incident mixes triage and root cause analysis, because nobody can size a problem they do not understand.
What questions does triage answer?
Five questions. Every triage process, formal or not, is a way to answer them.
| Question | What you need to know | Where teams usually look |
| Is it real? | Is the signal a fault, a brief spike, a planned change or a broken check? | The alert history, the chart behind the alert, a second look after a few minutes |
| How bad is it? | Is it getting worse? Is anything user-facing degraded? | Service dashboards, error rates, latency, customer reports |
| What is affected? | Which services, nodes, customers or regions share the problem? | Other alerts, dependency maps, asking in chat |
| Who owns it? | Which team can change the thing that is failing? | Service catalog, on-call schedule, tribal knowledge |
| What changed? | What is different now from an hour ago? | Deployment logs, change tickets, configuration history, guessing |
The first four decide the response. The fifth is the start of root cause analysis, and it takes the time. It also makes the other four easy: when you know what changed and where, you know whether the alert is real, how far it reaches and whose it is.
How do you triage an alert, step by step?
Use the same steps every time. Consistency matters more than the exact list.
| Step | What to do | Decision |
| 1. Read the alert | What fired, on what, at what value, for how long. Has it fired before? | Known and harmless: close it. Otherwise continue |
| 2. Confirm the signal | Open the chart behind the alert. Is it a spike that ended, a step change, or a trend? | Already recovered: note it. Otherwise continue |
| 3. Look around it | What else became abnormal at the same time, on this node and on related ones? | Isolated: watch or act. Spreading: treat as an incident |
| 4. Check user impact | Errors, latency, failed checks on user-facing services | Impact confirmed: declare an incident and set a severity |
| 5. Find what changed | The first component that started behaving differently, and what it did | A lead for mitigation and for the owner |
| 6. Assign and communicate | One owner. One place for updates. State what is known and unknown | Hand over with the evidence, not only the alert |
| 7. Record the outcome | Real or false, cause, time spent | Fix or remove the rule if the alert was not useful |
Steps 3 and 5 are where the minutes go: opening dashboards, comparing time ranges by eye and asking people who know the system.
How do you prioritize incidents? A severity matrix
Severity is how bad an incident is. Most teams set it from impact and urgency, the two inputs ITIL multiplies into priority, and write the mapping down once, so nobody argues about it at 3am.
| Severity | Impact | Examples | Response |
| SEV1 | A critical service is down or data is at risk, for many users | Checkout fails, the primary database is unavailable, a region is unreachable | Page now. Incident owner and communication lead. Updates on a fixed interval |
| SEV2 | A critical service is degraded, or a major feature is down | High latency on the API, a queue backing up, a replica set without redundancy | Page now. One owner. Escalate if it does not improve |
| SEV3 | Limited impact or a workaround exists | One node of a pool is unhealthy, a batch job failed, a non-critical dashboard is stale | Handle in working hours, the same day |
| SEV4 | No user impact yet | A disk that fills in two weeks, a certificate that expires in a month | Ticket and schedule |
Set severity from impact, not from the name of the alert, and change it when the scope grows or the mitigation holds.
Why is triage the slow step?
Because an alert is a symptom with no context. An alert tests a hypothesis someone formed in advance, and incidents are rarely caused by what someone wrote a check for. The red light does not explain itself.
So the engineer does the explaining:
- Getting oriented. Which service is this? What does it depend on? Who knows it? On a system someone else built, this alone can take the first twenty minutes.
- Tab-switching. Metrics in one tool, logs in another, deployments in a third, tickets in a fourth, each with its own time picker.
- Speculation. With no evidence in hand, the investigation starts with a guess: it is probably the database. Then comes the work of proving or dropping it, and then the next guess.
- Tribal knowledge. The person who has seen this before is asleep, on holiday or gone.
Engineers call it “the 20-minute gap between ‘alert fired’ and ‘we actually understand what’s wrong’”, and on harder incidents “the 30-60 minutes before RCA”. It starts from zero every time.
The numbers agree that this is where incidents hurt:
| Finding | Source and year |
| 43% of respondents say they spend too much time responding to alerts | Splunk, State of Observability, 2025 (1,855 respondents) |
| 59% of engineers say half of the incident alerts they receive are not helpful, and 43% say alerts lack the context to understand them | Chronosphere, 2023 (500 engineers) |
| In network teams, fewer than 45% of alerts are actionable on average | Enterprise Management Associates, 2025 (351 respondents) |
| Alert fatigue is the number one obstacle to faster incident response, named by 30% of respondents | Grafana Labs observability survey, 2026 (1,363 respondents) |
| The average customer-facing incident takes 175 minutes to resolve | PagerDuty with Censuswide, 2024 (500 IT leaders) |
What happens when triage costs too much?
People stop doing it.
The arithmetic is simple. If understanding one alert costs twenty minutes, and a shift brings fifty alerts, nobody can look at all of them. So the team filters by habit: this one always fires, that one is usually nothing, mute this channel during the release. Most of the time the habit is right. The outage is the time it is wrong.
The surveys show the result:
- 73% of 1,855 respondents report outages linked to ignored or suppressed alerts (Splunk, State of Observability, 2025).
- 41% of 1,700 respondents learn about service interruptions from customer complaints, tickets or manual checks (New Relic, Observability Forecast, 2025).
- The median cost of a high-impact outage is $2 million per hour (New Relic, Observability Forecast, 2025).
The usual answer is to send fewer alerts: tune thresholds, group duplicates, silence the noisy ones. That work is worth doing, and our guide on alert fatigue covers it. But it treats the count. The other half of the problem is the cost of each alert. When an alert is understood in two minutes instead of twenty, the same team looks at all of them.
How does evidence-first root cause analysis collapse triage?
Every other investigation starts with a guess. Netdata starts with the evidence.
Netdata does the analysis before anyone asks. It trains machine learning models for every metric, stores the anomaly verdict with every sample, and has a scoring engine that ranks every metric for any time window by how anomalous it was, by how much it changed against the period before, and by what changed together with it. Of millions of metrics, only a few hundred show synchronized anomalies in the same seconds, so Netdata drills down to them instantly, however large the infrastructure is. So when an alert fires, the answer to “what was abnormal around this alert, where, and in what order” already exists. Nobody has to collect it.
This is what it changes for the five questions:
| Question | Without evidence | With Netdata |
| Is it real? | Wait and see if it fires again | See whether anything else turned anomalous in the same seconds. A real problem leaves a cluster of anomalies; a blip does not |
| How bad is it? | Open service dashboards one by one | The anomaly rate of every node in the window, ranked, down to the instance and the chart |
| What is affected? | Ask in chat, read the dependency diagram | Every component whose anomalies appear in the same seconds, across the infrastructure |
| Who owns it? | Guess from the alert name | The component that turned anomalous first, by name: the host, the container, the application |
| What changed? | Compare charts by eye | The ranked list of metrics that changed against the period before, anomalous or not |
One click. No prompts to write, no runbooks, no service maps, no instrumentation. On any alert, in the Alerts tab or from the alert email, one click starts Netdata AI on that alert. The scoring engine gives it the few hundred metrics that were anomalous or changed around the alert. The AI reasons over that evidence, runs its own follow-up checks, and returns a report in about two minutes: what happened, the root cause, and everything it affected.
Any alert explained in about two minutes, one click away, so alerts no longer pile up for triage.
Three things follow for the on-call engineer:
- You don’t need to know the system to find the cause. Netdata has already scored every metric and shows what changed. Every engineer, including the one covering another team’s service, starts from the same evidence as the person who built it.
- The handover carries the evidence. The owner receives the alert with the ranked list and the report, not a bare alert with “can you look at this?”
- The investigation can leave Netdata. Connect GitHub, Jira and PagerDuty, or any MCP server, and Netdata AI takes the investigation into your code, tickets and incidents.
If you prefer to look yourself, the Anomaly Advisor shows the same ranked evidence for any time window you highlight, and the root cause is usually among the top 30 to 50 results.
What does this look like on a real alert?
This example follows a real production pattern: a scheduled cleanup job disconnected thousands of clients, and the reconnect storm filled message queues for two hours. The components and timings below are illustrative.
A queue depth alert fires on a message broker in the middle of the night. It has fired before, during traffic peaks, and it usually clears. There is no traffic peak now.
Triage by hand. The engineer opens the broker dashboard: queues are growing. Consumers look healthy. Is it the producers? The network? Twenty minutes later there are three theories and no evidence for any of them. The alert clears, fires again, and is acknowledged twice more. The queues stay full for two hours.
Triage from the evidence. One click on the alert. The report reads the minutes before the alert and finds this order:
- About ten minutes before the alert, a scheduled cleanup job starts on one of the application nodes that hold the client connections. Its process group is the first thing that turns anomalous.
- Seconds later, open connections on that node drop sharply. The job disconnected thousands of clients.
- Within a minute, connection attempts and CPU rise on every application node as the clients reconnect at once.
- The reconnect storm reaches the message broker. Publish rates jump, and queues fill.
The five questions are answered in one read. It is real. By the matrix above it is a SEV2 that will not clear soon. It affects the application nodes and the message broker, not the consumers. The owner is the team that runs the cleanup job. What changed is the job and what it did. The mitigation is to throttle reconnects, and the fix is to stop the job from dropping live connections.
What does this change for the team on call?
Root cause in about two minutes. One click. Zero playbooks.
Netdata finds the root cause: the application responsible, what it did, and everything it affected. The alert queue nobody trusts becomes a list of explained alerts, because looking at one costs two minutes, not twenty.
No war rooms. One engineer, one click, the answer, with the evidence on the screen for everyone to check. No call with fifteen people guessing, and no blame.
It tells noise from an incident. Triage has to say “this is nothing” and be right. In an environment full of alerts and anomalies, Netdata says what is noise and what is real.
It finds the incidents no alert rule anticipated. Ask for the most intense events of last week, or put the question on a schedule. The scoring engine ranks every metric, with or without an alert on it.
On-call stops being feared. The 3 a.m. page is one click from its answer.
What are the best practices for alert and incident triage?
- Alert on symptoms that matter, at the level of the component. An alert that names the exact disk, container or service is half triaged already. Netdata ships more than 1,100 stock alerts as templates that attach to every matching instance as soon as it appears.
- One severity matrix, one owner per incident, one place for updates.
- Mitigate first when impact is high. Restore service, then finish the root cause analysis. Netdata stores the anomaly verdict with the data, so last night’s incident can be investigated in the morning.
- Review the alerts, not only the incidents. An alert ignored for a month is either wrong or unexplained. Explain it or remove it.
- Review what no alert caught. Netdata’s scoring engine finds the interesting time windows on its own, for example “the most intense events across my systems and applications last week”.
- Measure triage. Track the time from alert to first evidence-backed hypothesis. It is the part of time to resolve that tooling can remove. Teams that start from the evidence resolve incidents faster: Netdata delivers 80% faster MTTR.
FAQ
What is the goal of alert triage?
To decide quickly and correctly which alerts need a person, how urgently, and who that person is, so that real problems get attention and the rest do not consume it.
Who performs alert triage in IT operations?
The on-call engineer, most of the time. Larger organizations have an operations center that does first-level triage and escalates to service owners. In both cases the quality of the decision depends on the evidence available in the first minutes.
How is alert triage different from incident response?
Triage decides whether there is an incident and how severe it is. Incident response is the work of restoring service once that is decided. Triage does not end when response starts: the severity is reviewed as more is learned.
How long should triage take?
Minutes. A useful target is a first evidence-backed answer to “is it real and what changed” within five minutes of the alert. With Netdata the report on any alert takes about two minutes.
What is the difference between alert triage and alert correlation?
Correlation groups alerts that belong together, so one problem produces one notification. Triage decides what to do about it. Correlation reduces the number of things to triage. It does not explain them. See our guide to event correlation.
Can AI triage alerts?
Yes, when it starts from the evidence. The slow part of triage is collecting and reading the evidence, and Netdata AI does it in about two minutes. Handing a language model raw logs and asking what is wrong produces confident guesses. Netdata’s AI starts from ranked evidence: the metrics that were anomalous or changed around the alert. You start it with one click on an alert, with a question, or on a schedule. Teams that want investigations running on their own can talk to us about AI SRE.
Does faster triage reduce alert fatigue?
Yes. Netdata reduces alert fatigue through component-level alerts, intelligent alert configuration and root cause analysis one click away. The first two address the number of alerts. The third addresses the cost of each one, so alerts no longer pile up for triage.
Stop triaging by guesswork
Stop speculating. See what the data says before anyone forms a theory. You can install Netdata in the middle of a crisis and get real-time insights and AI-assisted troubleshooting immediately. Anomaly scores follow after about 15 minutes. Netdata is open source, and a Netdata Cloud trial is all it takes to run evidence-first root cause analysis on your own alerts. Start a trial, or book a demo and bring the alert your team has learned to ignore.
Related guides: anomaly detection in monitoring, dependency mapping, runbooks and incident management.
