As your infrastructure grows, so does the complexity of monitoring it. The traditional approach often involves deploying a software “agent” on every server, virtual machine, and container. While effective, this can quickly become a management nightmare. You have to install, configure, update, and secure hundreds or even thousands of agents, each consuming precious CPU and memory on the hosts you’re trying to monitor. What if there was a less intrusive way?
This is the promise of agentless network monitoring. It’s an approach that allows you to gather vital health and performance data from your network devices and servers without installing any dedicated, third-party software on them. For teams managing large, diverse, or security-sensitive environments, this method offers a compelling alternative that can simplify deployment, reduce overhead, and broaden visibility.
This guide will break down the mechanics of agentless monitoring, weigh its pros and cons against the agent-based model, and help you understand when it’s the right strategy for your IT infrastructure.
What is Agentless Monitoring?
Agentless monitoring is a technique where a central monitoring server directly polls your network devices to collect metrics. Instead of relying on a custom agent to push data out, the monitoring tool uses standard, built-in protocols and APIs to pull data in.
Think of it like this: an agent-based approach is like having a dedicated reporter on-site at every event, sending back detailed dispatches. An agentless approach is like calling the event organizer on the phone to get updates. Both can give you the information you need, but they do it in fundamentally different ways.
The most common protocols used by agentless monitoring tools include:
- Simple Network Management Protocol (SNMP): The de-facto standard for managing and monitoring network hardware like routers, switches, and firewalls.
- Windows Management Instrumentation (WMI): A core component of Windows operating systems that provides performance data and management capabilities.
- Secure Shell (SSH): Used to securely connect to Linux/Unix servers and run commands to gather metrics.
- Application Programming Interfaces (APIs): Many modern applications and cloud services expose their metrics via REST APIs, which monitoring tools can query directly.
Agent vs Agentless Monitoring: A Head-to-Head Comparison
The debate between agent-based and agentless monitoring isn’t about which is definitively “better,” but which is better suited for a specific task or environment. Let’s compare them across several key criteria.
Deployment and Maintenance
This is where agentless monitoring has a clear advantage.
- Agentless: Deployment is fast. You only need to configure the central monitoring server with the correct credentials and IP addresses for the target devices. There’s no software to install on hundreds of hosts. Upgrades are also simpler, as you only need to update the central server.
- Agent-based: Deployment can be time-consuming. You must install and configure an agent on every single device you want to monitor. This often requires automation tools like Ansible or Puppet. When the monitoring platform is updated, you may need to roll out updates to all agents across your entire fleet.
Resource Consumption
- Agentless: The impact on the monitored device is minimal. The only resource consumption happens when the device responds to a poll request from the monitoring server.
- Agent-based: An agent is a running process that consumes a certain amount of CPU, memory, and network bandwidth on the host. While modern, high-performance agents (like Netdata’s) are designed to be extremely lightweight, they still have more overhead than a purely agentless approach.
Security Profile
The security implications are nuanced and depend on your perspective.
- Agentless: This approach relies on having management protocols like WMI or SSH enabled and accessible over the network. You must ensure these protocols are securely configured with strong credentials and firewall rules. The monitoring server becomes a single point of control with access to many devices, so it must be heavily secured.
- Agent-based: This method introduces another piece of software into your environment that needs to be vetted, secured, and kept up-to-date. However, communication can be encrypted, and it doesn’t require opening remote management ports on every device, which some security teams prefer.
Depth and Granularity of Data
This is the primary trade-off.
- Agentless: The data you can collect is limited to what the exposed protocol (SNMP, WMI, etc.) provides. This is excellent for high-level health metrics—CPU utilization, memory usage, network traffic, device uptime—but often lacks the deep, granular insights needed for complex troubleshooting.
- Agent-based: An agent has direct access to the host’s operating system kernel and processes. This allows it to collect a much richer and more granular set of metrics. It can provide per-process resource usage, detailed application-specific metrics, and real-time, per-second data that is often impossible to get via polling.
When Should You Use Agentless Monitoring?
Given the trade-offs, agentless monitoring excels in several specific scenarios:
- Monitoring Network Hardware: For devices like switches, routers, printers, and UPS systems, agentless is the only viable option. These devices don’t allow you to install custom software but almost always support SNMP.
- Large and Heterogeneous Environments: If you need to monitor thousands of devices from various vendors, the simplicity of agentless deployment makes it far more scalable. Agentless network discovery tools can scan your network and begin monitoring new devices automatically.
- Security-Restricted Zones: In highly secure environments where installing any unauthorized third-party software is strictly forbidden, agentless monitoring may be the only approved method for gaining visibility.
- High-Level Health Checks: When your primary goal is to check for availability and basic performance across a wide range of systems, agentless monitoring provides a quick and efficient way to do so without the overhead of full agent deployment.
The Hybrid Approach: The Best of Both Worlds
For most modern organizations, the choice isn’t a strict “either/or.” The most effective monitoring strategy is often a hybrid one that leverages the strengths of both methods.
- Use agentless monitoring for breadth: Deploy an agentless monitor to get broad visibility across your entire network. This covers your network gear, IoT devices, and provides basic health checks for all your servers.
- Use agents for depth: On your critical application servers, database servers, and Kubernetes nodes, deploy a high-performance, lightweight agent like Netdata. This gives you the deep, granular, real-time data needed for performance tuning and rapid troubleshooting of your most important services.
This hybrid model allows you to achieve comprehensive observability. You get the scalable, low-overhead benefits of agentless monitoring for your wider infrastructure, combined with the powerful, detailed insights of an agent for the components that matter most.
Ultimately, agentless network monitoring is a vital tool in any modern IT toolkit. It offers a flexible, scalable, and efficient way to gain visibility into parts of your infrastructure that would otherwise be difficult or impossible to monitor. By understanding its strengths and limitations, you can make an informed decision and build a monitoring strategy that is both comprehensive and manageable.
Ready to see how a high-performance agent can provide unparalleled depth for your critical systems? Sign up for Netdata for free and experience real-time, granular monitoring in minutes.
